AnEv942
Dec 21, 2016Nomad
Portable would be less so with an attached tank..on board system tank gets mounted on truck. But not all on board systems include a tank.
We are constantly adjusting air bags, whether taking camper on/off, adjust to get level, road conditions. Upgraded to onboard- worth the price for the added convenience-its just push a switch anytime, camper on or off to adjust bags. Tires not so much.
I do have tank on onboard system and set up to use for other air needs. However I don't use unless really necessary for tires, too much run time for the small air bag compressor. I carry a small 110v electric compressor in camper that I use with gen. for tires. As tire filling is a manual thing anyway kinda made sense.
Works for us- air is pretty much required I couldn't limit source to one compressor.
In your case, adjusting tires over bags, a small on board without tank dedicated to bags would give you the convenience with a bit less cost- then a better portable for tires. Or, just the better portable for the volume to fill tires and manually adjust bags.
I wouldn't use on board air bag compressor where its primary duty would be filling tires. You can always do onboard for bags later if the convenience seems justifiable.
