Moomba2002
Dec 22, 2016Explorer
I run onboard air with the ExtremeAire Magnum 150 PSI 100% duty cycle with a 4 gallon tank. Love the setup not the least expensive by any means but quality cost. They also sell the same compressors in portable versions if you feel you don't need a tank. If you are going to be filling tires to 80 PSI you best get a good compressor as that type of use will burn up most units in time. I will see if I have any photos of my install I can post or PM you.www.extremeoutback.com
