dadmomh
Nov 30, 2014Explorer
So, with that said, the OP is asking for help, not an English lesson.
Agree that you cannot do anything with everything frozen. Suggest that if you haven't already headed home, when you do keep a very close eye on all the fittings inside cabinets, etc. Maybe invest in some plumbers tape or something to seal off any leaks until you can thoroughly check it out. You don't need a flood inside. You may be fine, you may have a puddle. Also, suggest you don't try the water pump until you get home. The temps here in West TN have been in the mid 60's and to continue a few more days....you're probably similar. Good luck with this....another one of those lessons learned the hard way. Sorry.
44,056 PostsLatest Activity: May 04, 2014
