the_bear_II
Aug 13, 2015Explorer
I have a 15,000 LB 5th wheel/ 3200 LB pin weight. I've towed it with two SRW pickups and two DRW pickups. The DRWs both have felt more stable in towing the 5th wheel. All 4 trucks had plenty of capacity for the 5th wheel. Both SRWs felt squishy in the rear end when turning or quick avoidance maneuvers.
While towing with one of the DRW I had an inner dual go flat just at the beginning of a long bridge. I was able to continue towing until I reached the end of the bridge and the exit to get off and put the spare on. I'm not sure I would have been able to do that with a SRW.
I will always buy a DRW truck for heavy loads.
44,056 PostsLatest Activity: Nov 19, 2013
