burningman
Feb 23, 2018Explorer II
HMS Beagle wrote:
Air bags have the advantage of being highly progressive and easily adjustable, which springs (steel or rubber) are not.
If you ever run the truck without the camper, I'd use airbags, and adjustable shocks like the Rancho 9000. You just can't make a non-adjustable suspension work well with 2000 lbs on it empty and 6000 lbs on it loaded. If you tune the steel and rubber to work well in one condition, it will work poorly in the other.
Perfectly stated. Go with Timberns or stiffer springs if you never use your truck for anything but hauling your camper.
It baffles me that guys balk at a few hundred dollars for bags but spend crazy money on other things, not to mention $75,000 trucks and $50,000 campers!
Airbags are cheap!
44,027 PostsLatest Activity: Mar 05, 2025
