hohenwald48 wrote:
Little bit off topic. For the folks who store things (other than sewer hose) in the original 4" steel bumper, do you have a problem with that stuff getting wet? Does the gutter drawer hold water?
I haven't noticed any water. Though I don't pull the gutter drawer out hardly ever either. I only cut a small piece of 2x4 and screwed it in the middle to soo stuff sliding into the center, no ends on the gutter.
I have the bumper ends caps that you squeeze the center to remove or install. Replaced the stock caps with the gaping center hole. Don't want any nest builders in there if I can help it!!!
