ksg5000
Jan 16, 2015Explorer II
Most roof issues can be fixed with Eternabond tape -- lots of info on the web and is permanent fix if applied properly. On vertical issues I use pro flex sealants. Most will tell you to avoid anything with silicon because it rarely works and other sealants won't stick to it.
Not sure what you have to "remove" from your roof but be careful about what you use to remove the old sealant as it can damage the rubber roof. Eternabond can be applied over most sealants.
Fans, heat and bleach can help with drying the rig out and mitigating mold.
44,071 PostsLatest Activity: Aug 30, 2026
