myredracer wrote:
If you were in the US, by code, pedestals are supposed to be at the left/rear of sites and you will rarely need a longer shore power cord. Canada doesn't have those codes and pedestals can be a long distance away. I've heard of up to 100' in some Ont. CGs.
We carry a spare 30 amp shore power cord with twist-lock connector on it. Also have a 30 amp generator adapter like in this photo. Allows the two cords to be connected together. Have rarely needed to do that but when you do, you really need it!
Tip: Always keep your shore power cord blades clean and shiny with sandpaper or emery cloth. Never plug into a pedestal (or at home) unless the power is turned off otherwise you will cause pitting & dirt on the blade surfaces and inside the cord connectors where you can't see what condition they're in, which can lead to overheating.
I have seldom needed a second cord, but I always have one set up to plug
into my other 30 foot. I also carry connectors for 50 amp to 30 amp.
30 amp to 15 amp ect... I haven't camped in Canada, so I haven't encountered any long runs for power. The longest I have encountered was years ago camping on the river at the Rome, Ga. lock and dam. Some spots had no tower, so I run my cables under my RV to the next site, which was empty.
