obedon's avatar
obedon
Power Cable Extension options ??
I am still in the early days with my 2018 Rockwood Signature 8335BSS, 36ft long. We were at a campsite where we needed to rent an extension cord to reach the outlet. 30 AMP set (I think). I then went out and bought a second cord thinking it could be chained with my existing cord if needed but this weekend I noticed the female connectors only match with the trailer connector and not with the cord plug ends. Are there any recommended adaptors or do I need to shop for an extension cord model?? Many thanks!
  • I am always nervous when new RVers talk about buying extension cords because they might believe the size and length of the extension makes little difference. They both do...lots of difference.
  • If you were in the US, by code, pedestals are supposed to be at the left/rear of sites and you will rarely need a longer shore power cord. Canada doesn't have those codes and pedestals can be a long distance away. I've heard of up to 100' in some Ont. CGs.
    We carry a spare 30 amp shore power cord with twist-lock connector on it. Also have a 30 amp generator adapter like in this photo. Allows the two cords to be connected together. Have rarely needed to do that but when you do, you really need it!
    Tip: Always keep your shore power cord blades clean and shiny with sandpaper or emery cloth. Never plug into a pedestal (or at home) unless the power is turned off otherwise you will cause pitting & dirt on the blade surfaces and inside the cord connectors where you can't see what condition they're in, which can lead to overheating.
