thejustin
Aug 22, 2013Explorer
Wanted to mention that when I am plugging into shore power, *EVERYTHING* electrical is turned off. Water heater, fridge, etc...
Just did a bit more poking around, I found if I turn off all the breakers and plug into shore power, GFCI doesn't reset. Going down one at a time, there is a 15A breaker (3rd one from top) that trips the GFCI, I can turn on all of the breakers except this one and the GFCI doesn't trip. The inside power panel is not labeled so I do not know exactly what the 15A breaker is for.
The microwave lights up but as soon as I try and use it, I can hear the reset button popping and everything powers down. There are also a few dead power outlets in the kitchen area. I will try and hunt down all the GFCI outlets and resetting them tomorrow and see if that helps any. There is also an inverter on board and it is plugged into a GFCI plugin in the access panel below the entry step, was told to check for some reset buttons at the base of the inverter, will try that tomorrow. It is about midnight here and I can't see anything very good in my driveway heh.
