thejustin
Aug 29, 2013Explorer
mark_be wrote:
Found anything yet?
Here is what I have found....
The converter is indeed charging the house batteries when either the onboard generator is running or plugged into my Yamaha generator. The GFI on my garage outlet trips as soon as I plug in there. I opened the electrical access panel and see the power converter is plugged into a GFI outlet in the access panel under the camper. If I unplug it from there, and run an extension cord and plug it into a different outlet and then connect my shore power, everything works fine. Going to try replacing the GFI outlet under there and see if that fixes the problem....
