Old-Biscuit
Nov 23, 2013Explorer III
Don't be surprised that the converter is the problem.........battery is dead because charger section of converter isn't putting out proper voltage to charge/maintain battery and the lights dimming/getting bright is the converter struggling to produce needed voltage.
With battery disconnected......trailer plugged into 110V AC.....check that converter is getting AC power (outlet it is plugged into or at circuit breaker if hardwired) then check converter output at terminals on converter where battery cables connect........output voltage should be 13.6V DC
If converter isn't putting out 13.4-13.6V DC it is in trouble.
