dwayneb236 wrote:
RavensFan24 wrote:
I've never had an issue with our electric jack, but out of curiosity...how do you manually raise and lower an electric jack? If i ever run into the issue, I'd like to be prepared. I didn't know manually raising and lowering was an option. I got an electric jack, so I could quit sweating it out in FL weather trying to get set up/breaking down at a campsite.
I have a Husky. There is a rubber plug on the top that you just take out and put in the supplied jack handle. I've never used it but it doesn't look too complicated even for my simple mind. There is also something which I don't know how to describe on the side that you click over to disengage the motor before the manual jacking. I think I have a little tool for that too.
I must find that disengaging thing as I assume that must be why it's so difficult to do it manually.
Oldcow
