Lessmore's avatar
Lessmore
Explorer II
Apr 05, 2018
Power steering fluid
Question about power steering fluid. I have an older GM ( '07 Buick LaCrosse) vehicle which in the past has leaked power steering fluid. If I were to add some, do I need to add the same brand, same type, etc. I think it has a silicon type fluid now...would it need to be silicon fluid ?
Any issues, concerns that I should be aware of ?
Thanks.
  • I've never heard of a silicone base power steering fluid. Look on the cap of your P S reservoir it should state the type of fluid to use.
  • I wouldn't mix a mineral base fluid with a silicone base fluid. The brand on the other hand doesn't matter.
  • Far easier to ask on a forum than read an owner’s manual, wildtoad.
  • Do you have and have opened your owners manual which should state what type of fluid to use. In anycase you should should address the cause of the leak.
  • Your owners manual will tell you what type of fluid it uses, probably Dexron or equiv.
  • Since it is leaking I would get some power steering stop leak such as Barr's and then top off with any good quality power steering fluid but not synthetic.
