bguy
Jan 23, 2014Explorer
Mine ( I don't know the model # ) has a plastic cover on the head with 4 Philips screws. Under there is a plate retained by more Philips screws. IRRC you will have to remove the ground wire to lift the plate then you can access the switch area. Don't forget to remove the fuse. All the wires will be live.
44,057 PostsLatest Activity: Mar 12, 2026
