Delano1981's avatar
Delano1981
Electric Tongue Jack Power Problem
If anyone has any electrical experience, I have a problem with this electric tongue jack I purchased from eTrailer.com:
https://www.etrailer.com/Camper-Jacks/Buyers-Products/3370093500.html
It has a 7 pin plug like the standard plug on a trailer that you can plug into the truck for power. The problem is that the jack doesn't work when I plug it into the truck 7 pin connector, even though I have verified 12V power and ground is present on the correct pins of the truck connector. But, if I run a jumper wire from the positive post of my trailer battery to the correct 12V power pin on the jack 7 pin connector, it works perfectly. My guess is that it is not getting ground when plugged into the truck. Any ideas on what could be wrong?
Thanks
