westend
Jan 23, 2014Explorer
You should be able to pry the switch out by using a flat blade screw driver under the lip of either the top or bottom flange.
That is a fairly simple switch. Here is a replacement 25 amp switch. You would have to change the wire connections to use it as this has six blades versus the original that has four blades and jumpers. For $45 difference, I would change the connections.
44,057 PostsLatest Activity: Mar 12, 2026
