Dslr's avatar
Dslr
Pre-Buy Inspection
I know a lot of people have found issues on travel trailers before they leave the lot but in a lot of cases they find them on the first trip out. As a newbie, is there any recommendations for the pre-buy inspection? What should I make sure I look at before the trailer leaves the lot?
I did a search for pre-buy inspections, but nothing came up.
  • During our pre-buy our salesman was very feature savvy. We opened every drawer, door and hatch and asked lots of questions most of which he had heard before I am sure.
    During the PDI the technician showed us everything including how to light the oven, where the water pump, water heater and TV antenna crank were. We took pictures and had another tech show us where to put the jack to change a tire.
    The dealer supplied the WD hitch as part of the TT deal. They explained the hitch setup so I would understand what it did and how it worked.
    What did we miss? I took me a while to find the low point drains and since it was a used TT, several of the drawer slide mounts were broken. Apparently a common problem. I repaired them myself.
    My DW and I are not afraid to ask questions and re-ask if we do not understand.
    Remember, the dealer does not know how much camping stuff you can't live without, nor do they know the max cargo rating of your vehicle. They do not know if you boondock or KOA camp. They read the same truck info sheets you do.
    The dealer wants to sell you the TT you want, not the one they think you should have.
    We do have a number of well established dealership and we spent a long time deciding on what we wanted. We even rented a similar unit to see if we liked it on the road.
  • in our last 4 pdi's we knew more about the units components than the technician Concern yourselves more with build rather than components. Avoid sales tricks
  • I spent some time on PDI but still I have found some small things here at home that I can fix in 10 min myself and as long as everything is in good working order this spring I'm good. I do have a good dealer just 5 miles away.
  • I prefer a slow, thorough PDI vs. the 20 minute version.
    Check everything, every latch,switch handle drawer, valve, light,catch,
    underneath, on top check it all.
    Curb your enthusiasm and check it all. Do not let them rush you. Once complete let them know of your concerns. Inform them before your PDI that you plan to do a very thorough inspection.
    I have purchased 2 new units. Neither ever returned to the dealer for warranty work.
  • Someone here has a list that would be helpful. Otherwise, if you can find a dealer with a stellar reputation that has been in business a very long time, don't sweat the long PDI and just plan on taking it back. No matter how good the PDI, if your picky (like me) you'll end up taking it back eventually anyway.
    That's exactly what I did. My PDI lasted 20 minutes or less. I went back with a list (including a huge mistake) and they not only took care of me, they also went to bat for me with the manufacturer.
    Good luck and enjoy the hunt!
    Scott
