I have seen these offered. Sometimes they are used with a racecar in conjunction with a system designed to provide oil in case of extreme G forces involved in turns which may result in the oil sump drawing air under power. Pre-oilers are also used for
aircraft engines, lending credence to their effectiveness.
Recently I also saw a pre-oiler designed for preparing new engines for first start-up. It was basically a pneumatic powered oil-tank. Newer engines don't have distributor driven oil pumps that can be driven by an electric drill prior to first fire. Newer engines have the oil pump connected directly to the crank and require the crank to turn before they even began to pump.
Another recent observation was that Ford has a TSB about pre-oiling these new distributorless engines (before 1st fire) claiming that some are damaged by not doing so. Ford recommended pre-charging the oil pump during assembly and further, cranking with the fuel pump off to prevent immediate starting before allowing a new engine to 1st run.
Lastly, I just offered
this link in my most recent "Death of an Excursion" post. The article details engine damage caused by non-Ford oil filters that have no anti-drainback feature and the dangers of using incorrect weight oil in Ford engines.
No doubt some of these new engines are very touchy about oiling, especially overhead cam motors.
Wes
