Buzzcut1
Nov 23, 2014Nomad II
covered wagon wrote:coolmom42 wrote:
Great ideas!
A tip on the fiberglass---you could put it in some trash bags to make it easier to handle, and keep the backing dry. That stuff is nasty if it gets in your clothes.
I agree with this Buzzcut as that fiberglass dust migrates everywhere with little air currents inside the camper. I have cut a piece of similar foam insulation to fit behind the same compartment door as a solution.
Thank you for the tip on the crank handles.
The dump valve compartment (pictured) is sealed from the rest of the camper so I don't worry about the fiberglass. The other batts on compartments that do have internal passage to the TC are enclosed
44,056 PostsLatest Activity: May 04, 2014
