jmtandem
Nov 23, 2014Explorer II
Tire chains: put them on at home before the trip to make sure they fit at you can do it with ease. I use industrial zip ties to secure any excess links to prevent damage to the truck and I use a small wood block that fits in between the cross links. Just drive up onto the block and now the chain is free from the tire, no yanking pulling or cussing while getting the chain in place. you then pull forward a foot and retrieve the block.
And if you have a dually and only want to chain the outer rear duals, just drive the inner dual on a block of wood so the outer is off the ground and totally easy to put the chains on as it is a couple inches clearance off the ground. Very easy/quick for the dually guys.
44,056 PostsLatest Activity: May 04, 2014
