tad94564
Nov 24, 2014Explorer
The Mad Norsky wrote:covered wagon wrote:coolmom42 wrote:
Great ideas!
A tip on the fiberglass---you could put it in some trash bags to make it easier to handle, and keep the backing dry. That stuff is nasty if it gets in your clothes.
I agree with this Buzzcut as that fiberglass dust migrates everywhere with little air currents inside the camper. I have cut a piece of similar foam insulation to fit behind the same compartment door as a solution.
Thank you for the tip on the crank handles.
Was thinking after reading this last night. Could a person just use some king sized pillow cases to hold the fiberglass?????
Flexible enough to bend around stuff, but more durable than a trash bag.
The fibers/dust would still get through the clothe.
Make the case out of house wrap. Then it will let water out, and hold the dust/fibers.
44,056 PostsLatest Activity: May 04, 2014
