- mobeewanExplorer
Sam Spade wrote:
mobeewan wrote:
Did you flush and sanitize it like the rest of the system? There could have been some residue in the bladder that takes a few fill and drain cycles to clean out.
This could be difficult to fix......since draining the whole system may NOT drain the small amount of water that is captured in the pressure tank. Especially if the tank is mounted with the inlet at the TOP.
The tank may have to be disconnected to be flushed good.
I suggest you call the company that makes the pressure tank.
I installed my tank on its side. The cold water line running to the water heater has a tee that goes to the toilet. I installed another tee in order to add the captive air tank in the line going to the toilet. I also added a valve right before the new tee.
When dewinterizing and sanitizing when hooked up to city water or running the pump I can let the tank fill, then shut off the valve, then flush the toilet until the tank empties. Then open the valve to refill the tank and repeat as many times as needed. The tank and valve are under the bunk right outside the bathroom door and the toilet is right next to the door. No problem flushing the tank without removing it.
Using this method, it would not matter what position the tank is installed, since the air in the tank will squeeze the bladder to empty it fully as long as the toilet flush valve is held open until the water stops flowing. - colliehaulerExplorer III
mobeewan wrote:
This would be my opinion as well. Don't remember any rubber taste from my R.O. home accumulater tank, did flush with bleach when installed.
Did you flush and sanitize it like the rest of the system? There could have been some residue in the bladder that takes a few fill and drain cycles to clean out. - Sam_SpadeExplorer
I suggest you call the company that makes the pressure tank. - mobeewanExplorerDid you flush and sanitize it like the rest of the system? There could have been some residue in the bladder that takes a few fill and drain cycles to clean out.
- 2manytoyzExplorer III wonder if the one you have was intended for drinking water. Pressure tanks also get installed on well water lawn sprinkler systems. Those don't need to be drinking water compatible. Maybe different bladder material is used... just a thought.
44,068 PostsLatest Activity: Jun 09, 2026
