SoundGuy
Jan 05, 2017Explorer
Jebby14 wrote:
I have a friction sway bar I will use with this hitch.
Is this for use with the trailer pictured in your SIG and if so is it already mounted? If not, if this sway bar is a fresh mount then it will require holes be drilled into the trailer frame if any existing holes don't line up. I only mention this because I've seen pics of sway bars repeatedly added to a trailer, the result being the frame looked like swiss cheese full of holes. :E This is one of the advantages of weight distribution systems such as the Equal-i-zer, Blue Ox Sway Pro, etc, which feature integrated sway control, don't require the use of any separate sway bar, and which simply clamp to the trailer frame, thereby meaning NO holes need be drilled into the frame at all.
