RoyB
Oct 13, 2015Explorer III
You will probably have to pay dearly getting an electric line run to your property...
Once the electric pole gets installed then install your RV PEDESTAL on the same pole...
Quite certain you will have to have a sewer spetic system installed or have it trucked away. You will also have to have a fresh water supply installed as well...
All of this will add up quick...
This will be a COUNTY issue... They don't allow any of that here in our county but have seen that done in counties near the BLUE RIDGE/SKYLINE DRIVE high country here...
The trailer also probably have to past the county inspection to be approved to be lived in... You may not get this approval without an Electric pole, septic tank and fresh water well installed. Your trailer may also have to fitted with a real foundation and not just sitting on tires to be legal...
Trailers on tires would not be the best situation to be in for the summer storms... A trailer sitting in an open field will be hit by lightning for sure could be blown over is just a 50-60mph wind storm...
Check with the local county laws on this... A legal residence also has to be identified in the county books for tax purposes...
Just some of my thoughts here
Roy Ken
Roy Ken
