Old-Biscuit
Oct 13, 2015Explorer III
Heyruthie wrote:
OK, these are all VERY helpful responses. I'm going to go re-read this thread several times, and start considering the things you are sharing--very informative! A few other questions:
-Some people seem to indicate that they "just use an extension cord" if the electrical source is nearby. Even as a temporary measure, I thought this could damage your RV electrical system! Is that not true? Now I'm confused.
-There is no way to flush waste tanks into an existing toilet, right? (Gross, I know, but I'm just looking at ways that might even be temporary.)
-Are there specific models that have the "enclosed underbelly" that anyone can recommend?
Thank you!
Extension cord.........some have used an extension cord with adapters to plug into a 15A outlet. That will provide enough AC power to run converter (charge batteries) and the Television.
NOT for living in unless you use propane for fridge/water heater No microwave and probably A/C Unit.
Now if you already have a 30A RV outlet you can use with an extension cord..YES (That would be an regular 120V AC outlet wired for RV plug NOT 240V 30A outlet wired for welder/dryer etc. 120V AC only be it 15A, 30A or 50A)
You can purchase a portable macerator that connects right on end of RV waste drain line........uses 12V DC and can pump waste (black/grey) up to 100' with a 2' rise thru a 3/4" garden hose.
I have one.....FloJet Portable Macerator. Use it to pump into sewer cleanout at back of sisters house when I visit (75' plus and at least 2' rise)
Pumping into toilet could work.......toilet bowl will continue to evacuate as bowl level rises provided no blockage which shouldn't occur cause macerator grinds up solids to flow thru garden hose
Enclosed underbellies is probably available on just about every brand anymore. Entry levels maybe not but entry level is not what you would want to live in.
AND you can always enclose/insulate underbelly your self. Big Box hardware stores carry 'coroplast' (plastic cardboard) and 'reflextic' (aluminum backed insulation) plus couple boxes of self taping screws
