Old-Biscuit
Jun 08, 2014Explorer III
New T-stats not properly installed.......they need to be tight against a clean surface on WH tank wall. Normal temp t-stat opens at 140*F. ECO t-stat opens at 180*F
When you say PRV 'spews' water.is it actually blowing water OR weeping water?
Weeping water can be due to loss of 'air pocket' in top of WH.
Turn off water, open a faucet, open the PRV via lever until water stops flowing out then let PRV snap close, close faucet, turn on water.
Electric doesn't work........tripped AC circuit breaker OR burnt up electric element.
44,068 PostsLatest Activity: Apr 17, 2021
