DiskDoctr
Jun 09, 2014Explorer
ScottG wrote:
Once a TPO spews hot water because of being over temp, it's shot because there's wax in it that melts. You have to replace it after fixing the root problem.
Your statement certainly seems to say that because the wax melts the first time the TPO is ruined.
I've had them wear out, but most often due to crud in the TPO, interfering with operation, mostly resulting in a leaking valve.
As politely as I can say it, I am quite certain TPOs do NOT fail, requiring replacement the first time they are tripped because of a melted wax component.
I didn't realize there was wax sealed inside the unit, however. That was an interesting piece of info.
44,068 PostsLatest Activity: Jun 14, 2026
