dmcrick
Jun 13, 2014Explorer
The model is GC6AA-9E. I am sure the new thermostat is properly seated against the tank. I did clean the spot off on the tank before installing. It runs on gas for about 40 minutes and does not shut off. The pressure relief valve is not weeping water it is spewing water. I shut off the water heater at that point and run the hot water and it is extremely hot. It will not run at all on electricity. The trailer is a 2000 Nomad. I have opened the pressure relief valve all the way and closed it. There are two problems. It does not run on electricity and will not shut off automatically on gas.
44,068 PostsLatest Activity: Jun 14, 2026
