JRscooby wrote:
About 10 years ago I had a recital/cranial inversion while moving trailer around in the lot, and mangled the plug. When I replaced it, hooked up tested all lights and brakes. Then I pulled the cap lose, buried all screws and connections in clear silicone, put a bunch in the cap, and put it back together. A lot was forced out around the cord. Wiped all the excess off. Keep the socket well lubed with di-lectric grease, no more problems. (also made a place that holds the end when not hooked up)
Standard "RTV" silicones use acedic acid as part of the curing process.
Generally not recommended for use with electrical connections.
May work for a while but may have enough acid to eventually damage the wire you were protecting.
They do make "neutral cure" RTV which is a bit electrical connection friendly and a better choice over all for this use.
