soon2bexpat
May 10, 2020Explorer
Problems when replacing 7 pin connector
I have a Curt Bluetooth brake controller. Works great but last week, it kept going out on me. Figured maybe the unit was bad, being Bluetooth and all. Get unhitched and see that the problem is a cut in the cord on the trailer side of the 7 pin. So I order a new trailer side plug and cut off the old one. Here’s where everything goes to hell.
I thought I could pull the end off the old plug to see how the wires are hooked up. But it’s like a solid piece. So I figured the wires going into the end would be in order and proceeded to wire it that way. Plugged it into the tow vehicle, turned on the TV headlights and saw the running lights turn on the trailer. Good. But the other lights (brake & turn) wouldn’t turn on and the brake controller couldn’t make a connection. I disconnected the trailer but the trailer running lights stayed on. Couldn’t figure that one out, so I pulled the bulbs so that the trailer battery wouldn’t die (I’m boondocking).
So today, I figure I’ll give it another try. The TV manual had a diagram for the 7 pin (‘02 GMC Yukon XL). Turns out I had it wired wrong. So I rewire the trailer connector to match the TV diagram. But when I plugged it in, the only thing that worked was the left turn/left brake light. At least the running lights were off.
So now I’m stuck. Any suggestions?
