Amanda1982's avatar
Amanda1982
Replacing 7 way wiring connector and having problems
Hello out there!
We are traveling with our RV and long story short pinched our 7 way cord making a turn. It fried the battery and in turn now has to be replaced.
It is Sat. and luckily we found an RV place for a new cord and battery, but no service in.
We got the battery changed out, however I'm not sure where we messed up
With the wiring. I have working lights, right blinker, and the tongue jack is working, but is
REVERSED.
I have no brakes, brake lights or left turn signal.
The truck is not reading the trailer is connected.
If anyone can offer some help that would be wonderful!!
Thank you:)
Amanda
  • Have you checked the fuse box in the engine compartment? That's where I found my problem
    Test the truck plug to see if you have the electric there, if not it's probably a fuse in the engine compt.
  • dougrainer wrote:
    Dakota98 wrote:
    First off, your Tongue jack is self grounding & has a hot wire going directly to the battery. It has nothing to do with the 7-way.
    Does this help
    This is WRONG. This is not a RV trailer 7 way. There is NO yellow for turn signals Yellow is reverse on 7 way. RED is left turn on 7 way. Brown is RT and Green Running lights. BLACK is 12 volt positive. IF YOU LOOK AT THE PLUG CONNECTIONS ON A RV 7 WAY, IT WILL STATE WHAT COLOR FOR EACH PIN. DOUG
    Sorry, Wasn't paying attention when I pulled the image from the net.
    My Bad.
  • RoyB's avatar
    RoyB
    Explorer III
    You should have a BREAK AWAY CORD coming from the trailer that you connect to the bumper of the truck that will pull out a KEY PIN from the breakaway switch if the trailer becomes disconnected from the truck when being pulled.
    Should look something like this
    I use a D-CONNECTOR on my truck setup attached to the bumper through an existing hole around the trailer hitch that makes it easy to slip the break-away pin cord into it.
    This is a DOT SAFETY REQUIREMENT for all trailers that equipment with trailer magnet type brakes. Some Utility trailers are equipped with SURGE BRAKES and will not have this arrangement. All of the RV trailers I have ever seen all have the MAGNET TYPE BRAKES.
    The 12VDc POWER to operate this BREAK AWAY SWITCH comes from the trailer battery. If the trailer gets disconnected from the truck then the 7-way cable will also be yanked out and will not be able to use the 12VDC coming from the truck side.
    You should be able to see the Break away box and long coiled up wire cord that is suppose to connected to the truck...
    Usually the only things direct connected to your battery will be the large cables going back into the trailer to the converter/charger distribution panel, the trailer break-away switch box connections, and the trailer tongue jack connections. there may also be a circuit breaker wired directly if your trailer has a slide-out.
    Of course who knows what the previous owner has dreamed up with no documentation.
    I found the cell phone camera being an excellent tool to take a picture of things like where the battery connections are before removing the battery. After you get things working again I would mark the cables that go to the POSITIVE side of the battery with RED TAPE or RED FINGERNAIL POLISH...
    This happens alot to all of us getting in a big hurry and not knowing the trouble we are in until it comes time to hook it all back up. You are not the only one that has done this. Hopefully you can get your batteries connected correctly first and find the REVERSE POLARITY blown fuses that goes with that. That is the only thing that will make the trailer jack turn the wrong direction. Leads are reversed somewhere.
    Roy Ken
  • And watch color codes- the image given above is *not* the RV standard.
    Does this help
  • RoyB wrote:
    Anytime you find the motors going the wrong direction almost always means the battery got installed in reverse.
    Look on the 12VDC battery case and find the word NEG or symbol"-" and make sure this terminal is going to FRAME GROUND. It should be a large WHITE WIRE but someone may have changed the colors.
    The 7-way cables should have been replaced wire color for wire color.
    ETRAILER.com has utube video on installing the 7-way cable with plug.
    If the battery was installed in reverse you will have to look for additional fuses that are blown and will need to be replaced.
    Roy Ken
    Thank you so much! That helped alot.... I'm still trying to understand where
    The orange/black goes off of the battery? All the videos I'm watching don't have
    A break away cord to illustrate.
  • First off, your Tongue jack is self grounding & has a hot wire going directly to the battery. It has nothing to do with the 7-way.
    Does this help
  • RoyB's avatar
    RoyB
    Explorer III
    Roy Ken
