Lynnmor
Jul 07, 2013Explorer II
westend wrote:Hitch Pin wrote:It does not keep good in the tube, probably about a month with the tip sealed and in ambient temps. I've seen where others refrigerate it and have success. I actually use Geocel 2300 instead of ProflexRV. The products are nearly identical but I buy through a roofing distributor and prices are cheaper than RV parts distributors. Geocel 2300 has just a tad more elongation strength than ProflexRV.westend wrote:
ProflexRV technical data sheet. At average summer temps, the sealant can probably be worked successfully up to about 30 minutes. After that, it will be skinned over and be miserable to work. I usually work the bead into the joint immediately after I apply it since it is thicker than most sealants and I won't have to revisit a location.
Does it keep good if you don't use it all up at once, or does it dry up in the tube?
I called the company and they said that they were identical.
To seal a caulking tube, I use a product that looks like a miniature condom. 7526A11
Condom
To smooth a bead of Proflex, try dipping your finger in mineral spirits.
