nike_holleyExplorerJun 14, 2016Propane...We have dual propane tanks on the tongue, under a plastic cover... What's the easy way to check levels & not run out of propane..??.. Thanks... Nate
wanderingbobExplorer IIJun 14, 2016Leave both open , watch the red 'green , tanks will last a long time , When gauge turns red you are then running on a fresh tank . Look at gauge every 2 or 3 days . Only a real dummy will run out !
Related ContentPropane Refillsmy propane generator won't startPropane!Doing without propaneSmaller Propane Tanks
