MKirkland
Apr 28, 2013Explorer
Propane and Safe Alert
We're camping with some propane smell coming from the kitchen. The gas CO by Safe Alert will blast a siren occasionaly. It is a little windy. How much propane smell should I expect, if any?
Bob Landry wrote:A 20 pound tank should only be filled to 80 percent of capacity by law. Overfill it, leave it in the sun, the pressure safety valve is going to open and blow off gas (which you are referring to as venting a small amount). Apparently you have never seen a tank overfilled sitting in the sun.ploiselle wrote:
There is a chance that the tank was over filled and you are smelling the blowoff.
Blowoff from what? There is no blowoff. Even if the tank was overfilled, it's a closed system except for the regulator vent which may occasionally vent a very small amount of gas, but that's outside and under a cover and you would never smell it in the trailer.
