wickedstang03
May 02, 2016Explorer
Sorry I'm a newbie with propane fittings... So if I got a 3/8" flare tee and a 3/8" swivel connector like these
Then I should be able to then run low pressure rubber/flexible hose along the frame and pipe into where I need it into the bottom of a cabinet to attach to the heater that has a 3/8" flare male fitting.... And of course caulk and seal the hole where I drilled for the line in the cabinet..
Also when attaching propane copper fittings do the need soldered around joints or do they seal themself?
