Kayteg1 wrote:
What you call "quick connect" ?
My camper is having service hose with big plastic nut with female thread on it that turns CW on the cylinder valve.
But the cylinder valves beside the male thread for camper connection, also have female thread that threads CCW for old-fashion connectors.
I have both depends what toy I am using from the same cylinder.
A quick connect is an
output fitting similar to an air compressor fitting that allows accessories (like outside grills) to use the camper's propane source. It's not at the connection to the bottles.
A popup my in-laws used to own had one at the kitchen counter and one in an outside hatch and the stove was a portable unit you could use at either location.
