evanrem wrote:
I have a camp chef and just bought the hose I needed and it worked. Like others said I think you just take the regulator off and connect the hose to the quick connect.
Yep, exactly...
If the stove has the temperature/flow knobs then you should be good to go with a straight hose connection.
The problem is, most LP BBQ etc hose have a regulator on it and the flow is controlled on the reg before it goes to the burner...
So that's the thing to watch for.
Does the Stove/Grill/BBQ have control knobs on it... if so, just screw in a normal LP hose, put a quick connect on the other end, you should be good to go...
Hope that helps..
