mike/kellie wrote:
I should have been more clear on my set-up. I didn't want to use bottles anymore and decided to plumb direct into the camper. I had a 1/4" brass "tee" that came out of my propane manifold after the regulator and installed a cross with a ball shut-off. From the cross is a 1/4 male fitting. I had a propane company make a 15' hose with female fittings on each end. If we are cooking outdoors, I connect the hose to the cross fitting and drop it though a hole in that compartment (probably used to vent) and route it under the camper to the passenger side where we usually set up a small table to cook. The Weber has the same male fitting minus the regulator I removed and I hook it up. Works great and I have flexibility to where I can set things up. Eliminated small bottles completely.
Which Weber is that? On my Q the regulator and temp control are one piece.
