I am curious....  What can go bad on an RV propane tank that requires re-certification?  I am not looking for 'because the oppressive government says so'.  I am looking for some sort of technical issue that causes propane tanks to actually wear out and become unsafe.
Obviously physical damage to the tank - dents, gouges, corrosion, etc - can put the integrity of the tank at risk.  Those could be present at any time, and thus that tank should be re-evaluated when the damage occurs, not on a preset schedule.  Yes, propane tanks can have 100-200 PSI present in them.  But it is not the 2000+ PSI of a welding tank or 3000+ PSI of a SCUBA tank.  I suppose metal fatigue from varying pressure can impact the life of the tank...but the air compressor in my shop has similar PSI and cycles between empty & full a lot more often.  I don't need to re-certify the tank on the air compressor.
I did a little bit of Internet research.  It seems re-certification is only applicable toward tanks that are 100 lbs or less.  The large propane 'pig' behind a rural house does not appear to need re-certification, ever.  And it seems there is a lot more propane at risk there, compared to a RV/BBQ sized tank.
I just don't see a propane tank in a well maintained RV magically going bad and needing to be replaced.  My tinfoil hat is telling me this is some sort of industry regulation put in place by a political lobby to force people to buy new tanks every few years, and has little real world value behind it.  If only
Hank Hill was on this forum.  He seems like the guy who would give me a straight answer regardless of what the official rules are.  :)
Final question...  Has anyone paid to have their tank re-certified and been told it needs to be replaced (and why)?
Thanks,
-Eric
