ZeeLet50's avatar
ZeeLet50
Propane tank valve
I have 2- 20lb tanks with the valve that can point to either tank or stay in the middle. There is the gauge that reads either green or red if the tank is full. When I put the valve in the middle,should I not expect it to be automatic and pull from one tank then when that empty pull from the other? When I put it in the middle position, I get no gas???. Am I doing something wrong here? There is propane in both tanks.
