Seon wrote:
I have 40lb tanks without cover because there aren't any made if they are made, somebody plz provide a link.
I had thought of going from 30 to 40 lb cylinders and looked, but never found any hard covers, only soft covers. I wound up buying 2 more 30 lb cylinders instead.
I have seen where someone made one out of 2 separate covers. They trimmed the bottom portion off of one and cut the top portion off the other and pop riveted them together where they left an area that overlapped. You just have to make sure you pop rivet from the inside around the area that touches the cylinders. Maybe add a piece of eternabond on each rivit head so it doesn't rub on the cylinders.
40 lb cylinders soft covers
