coolmom42 wrote:
jfkmk wrote:
I echo not using the propane until you get the leak fixed!
How old is the trailer/tanks? It is highly unlikely the tanks themselves are leaking. Check out the hoses, regulator, fittings first. You can make a solution of dish detergent/water and brush it on. The leak will be evident by bubbling.
This.
And to be technically correct, what you have are propane CYLINDERS, not tanks. Tanks are the things that are permanently mounted on a motorhome or other vehicle. Cylinders and tanks are subject to a completely different set of rules for inspection and re-testing.
Coolmom42, I stand corrected! They are indeed cylinders, not tanks. My bad!
