jimh406
May 29, 2020Explorer III
JimbyBird wrote:
As a follow-on question, if I get a portable generator that will run on propane, how awkward/difficult would it be to connect it to the camper propane supply without pulling a tank out?
You can add an external propane connector. I’m not sure you want to do that though. There are some generators that will run on propane as well, but if you plan to run an AC, you’ll want an extended run time. Since the water heater/stove/refrigerator/furnace all run on propane usually, you will need big propane tanks to make sure you don’t run out.
