myredracer
May 27, 2016Explorer II
I recently bought a dual ram bottle jack. Collapsed height is only 7" and extends to 14" and will fit under an axle with a flat tire. Regular bottle jacks are too tall. $23 on Amazon. If jacking up an axle, you must be very careful not to damage anything - use a block of wood on top of the jack. Can also be used for doing your brakes and bearings at home.
There are other methods like using the Anderson leveler ramp to raise an axle high enough to get the wheel off.
