TNRIVERSIDE
Dec 31, 2014Explorer
srt20 wrote:
Should be no problems with pressure and foaming. If you are using a good fluid it will not foam. And as long as your vent isn't plugged it won't blow out any seals.
I used to race and had the rear gear housing 3/4 full of fluid. Anything less would get to hot and burn up the gears. Of course I had a vent with a hose on it to a expansion tank. That isn't needed on a stock type system that doesn't see extreme heat.
Fill it to to mag-hytec level and forget about it.
Thanks for the input from a voice of experience.
44,059 PostsLatest Activity: Mar 17, 2026
