JIMNLIN
Apr 20, 2017Explorer III
op wrote:
The owner of the tire business said that although I am not towing that load range E tires absolutely MUST be run at no less than 50 psi.
What the dealer is saying is for a LT tire get the same load capacity as your P tire they need 50 psi. Check out a P tire load pressure chart vs a LT load pressure chart.
Many 1/2 ton trucks door post psi is usually 35 psi....so to cover his azz (libility) he can only tell you to use 50 psi.
I use 35 psi in my wifes 1500 chevy crew cab 4x4 truck with LT C tires on the rear and 38 psi in the fronts when empty.
