rhagfo
Apr 20, 2017Explorer III
jefffoxsr wrote:
I called the tire manufacturer for my new tires. They said absolutely you can run under 50 psi in load range E tires. They said to refer to the tire and rim association load and inflation tables which also show load rates for inflation pressures as low as 25 psi for load range E 10 ply tires. I have this table and found it again on the internet to confirm it.
Some tire manufacturers publish documents showing what they determined to be the proper air pressure for their particular tires to meet OEM standards. They use the tire and rim association table as a starting point to make their determination for their specific tires. These are interesting to look at.
Anyway. I am satisfied, based on the above information, that I can safely run lower than 50 psi on my new tires.
Ding...Ding....Ding we have the winning answer!!
When will people realize the 80 psi on most E rated tires is the MAXIMUM pressure for the MAXIMUM LOAD!
If one is running empty, and you have 3,000# on the rear axle, and tires rated for 3,415#+ EACH you don't need 80 psi of air in them, you are greatly reducing the tires contact patch on the road, resulting in poor traction.
