Richandtd's avatar
Richandtd
Proper wood for trailer repair
Ok I believe that I still got a good deal on my TC but now I get to experience repairing the drivers side front corner where the support jack is. While my torklift fastguns were fastened down I noticed that where the tie down I bolt is attached that about a 1/2" gap appeared. This is right where the refrigerator vent is. Taking the access cover off I and see where a leak has caused some wood rot. I plan on removing the support jack take off the fiberglass around the area of the refrigerator access vent and replace the wood in that area. Also putting in an aluminum 3"x 2" angle support 8' along the bottom edge with both tie down I bolts going thru it with additional lag bolts attaching it to the bottom corner area. Then weld a flat aluminum 3" by 2' piece that the bolts that attach support jack with 1/4" longer lag bolts securing it to the corner since the aluminum will be 1/4" thick. I'll post pictures as I get into this project but the question is what kind of wood do I use for wood framing that I have to replace?
  • The camper manufacturer uses the cheapest wood they can source. Certainly not fine oak. Anything you use from the local big box dimensional lumber piles will be as good or better than original. Just try for straight grain knot free wood.
  • RoyB's avatar
    RoyB
    Explorer II
    I do all of my RV repairs with wood, plumbing, and electrical items from the LOWEs store. They seem to have all I need when something needs to be repaired...
    Roy Ken
