stripit wrote:
If the side forces with a conventional hitch are less, why do folks have to make steering corrections to a tow vehicle when towing a trailer with a conventional hitch and do not need to make them when towing with a ProPride 3P or Hensley Arrow?
Aren't the forces that cause the steering correction coming from side forces on the trailer and transferred through the receiver?
I didn't say anything about side forces on the trailer.
I was talking about yaw-axis torque applied to the receiver.
To answer your first question --
The lateral force applied to the ball of a conventional hitch on a Suburban acts at a distance of about 65" behind the rear axle.
The steering torque (in lb-inches) on the TV would be about 65 times the lateral force.
With a four-bar-linkage hitch, the lateral force acting on the ball is "projected" forward to a point about 22" behind the Suburban's rear axle.
The steering torque would be about 22 times the force.
If the lateral force is the same for the two cases, the steering torque with the conventional hitch would be about three times as great as for the 4-bar hitch.
Ron
